Home > Forums > FLUENT
UDF for defining a body force in Singel ROtating Reference Frame
Old   February 9, 2010, 01:06
Default UDF for defining a body force in Singel ROtating Reference Frame
Teymour
teymourj is on a distinguished road
Dear all,
I am trying to use Discrete Phase Model (DPM) to look at particle behavior in the solution of my Single Rotating Reference Frame (SRF) which contains my countinues fluid.
As long as SRF has rotating frames, therefore a Centrifugal and Coriolis term will be added to the equation of force balance of the particles. What I need to do, is writing a UDF which calculates these two forces. Then compile it with my model, so that it cancels those two additional forces.
I wrote a UDF based on UDF manual section 2.5.2 file:///usr/ansys_inc/v120/fluent//f...udf/node67.htm as follow, but it did not work out and I get error when I want to compile it. I was wondering if anyone can help me with that.
/* UDF for computing the force due rotating refrence frame on a particle */
#include "udf.h"
#define ROHR 1.5
/* density ratio of particles (roh/roh_p) */
#define OMEGA 1.78
/* angular velocity [rad/sec] */
/* Calculate some of centrifugal & coriolis force on a particle */
/* axis of rotation is "Y" and there are two force components in "X" and "Z" */ /* Fx= (1-ROHR)*OMEGA^2*x + 2*OMEGA*(u_z,p - ROHR*u_z), Fz= (1-ROHR)*OMEGA^2*z + 2*OMEGA*(u_x,p - ROHR*u_x) */
DEFINE_DPM_BODY_FORCE(particle_body_force,p,i)
real bforce=0;
if(P_TIME(p)>=TSTART)
{ if(i==0)
bforce=(1-ROHR)*OMEGA^2*P_INIT_POS(p)[0] + 2*OMEGA*(P_VEL(p)[2] - ROHR*rel_vel[2]);
else if(i==2) bforce=(1-ROHR)*OMEGA^2*P_INIT_POS(p)[2] + 2*OMEGA*(P_VEL(p)[0] - ROHR*rel_vel[0]); }
else bforce=0.0;
/* an acceleration should be returned */
return (bforce/P_MASS(p));
Thank you for your help in advance.
-teymourj
teymourj is offline   Reply With Quote
Thread Tools
Trackbacks are On
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Moving Reference Frame UDF Mark FLUENT 1 March 17, 2008 18:57
DPM and Forces in rotating reference frame Xiana FLUENT 2 March 13, 2008 07:00
Single rotating reference frame Belete Kiflie FLUENT 6 June 18, 2006 03:38
rotating reference frame Pei-Ying Hsieh Main CFD Forum 1 April 5, 2006 08:54
