multiphase heterogeneous reaction definition
Like Tree1Likes
  • 1 Post By coalgas
Old   February 9, 2010, 02:05
Default multiphase heterogeneous reaction definition
chétan
coalgas is on a distinguished road
Hello everyone
It is mentioned in UDF manual while defining DEFINE_HET_RXN_RATE macro, "The bulk phase can participate in the reaction if the phase does not have any species ( phase has fluid material instead of mixture material)".
I am trying to model reaction between air (primary phase) and carbon (secondary phase) to yield CO (of primary phase) with eulerian multiphase model. According to above discussion, I have defined secondary phase straightaway in DEFINE>PHASES>SECONDARYPHASE as Carbon which is fluid (not a mixture). Primary phase which is defined as DEFINE>PHASES>PRIMARYPHASE as "Gas-mix" which is mixture with CO CO2 O2 N2 as species, am I right??
And second question, with above procedure, when i define heterogeneous reaction in DEFINE>PHASES>INTERACTION>REACTIONS and tried to define heterogeneous reaction between primary phase (air) and secondary phase. I can not see Carbon in species? Have i done any mistake while defining heterogeneous reaction?
Thanks in advance.
souza.emer likes this.
coalgas is offline   Reply With Quote
Catalytic reaction in multiphase flow (NEED HELP) moataz.che FLUENT 0 May 4, 2009 12:23
Surface Reaction Model or Heterogeneous Rxn Model? satheeskannan FLUENT 0 September 2, 2008 18:55
Ansys CFX10: multiphase reaction heat problem CFDS CFX 1 September 20, 2006 23:09
chemical reaction in multiphase flow Domi FLUENT 2 October 20, 2004 07:06
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
