-   -   Convergence for Conjugate Heat Transfer (http://www.cfd-online.com/Forums/fluent/72540-convergence-conjugate-heat-transfer.html)
osgumero February 9, 2010 16:01
Hello all,
I'm relatively inexperienced with CFD and am trying to run simulations of conjugate heat transfer. While iterating, I am having problems getting the solution to converge.
What are possible remedies to obtain a converged solution? I know that refining the grid/mesh is one option but are there other things I should be looking into? For instance what would be the be best solution method (best as in the most accurate) for analyzing temperature gradients within a solid? Is there anything else that I should look into as well as refining my grid?
Thanks all
Jeremy
newdate4 February 10, 2010 06:53
If there arent any large changes in temperature, assign your fluid using the Boussinesq model & define the thermal expansion co-effiecient for the fluid in the material card.
