-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   "License server connection lost" error (https://www.cfd-online.com/Forums/fluent/72565-license-server-connection-lost-error.html)
curious_ssl February 10, 2010 06:27
I am new to CFD online as a user but I am a long time follower.
I run solid-gas two phase flow problem by using eulerian-eulerian model on a linux system. The cluster I use for parallel processing is in another city and I upload my files there wia ssh connection. Then I run fluent with the following command:
nohup fluent 2d -t16 -g <name_of_input>& name_of _output&
the input file is in text format.
The system has 8 blades with 16 cores on each. So, I use 1 blade.
Some time in the run I came across this message:
Warning: License server connection lost.connect to address 1.1.1.6 port 544: Connection refused
trying normal rsh (/usr/bin/rsh)
Permission denied.
then the run stops.
What could be the reason of this?
Thank you.
