setting up multiple runs
Old   February 11, 2010, 10:44
Default setting up multiple runs
Graeme
mapuma is on a distinguished road
Hi all,
I have searched but I can't seem find anything relevant to my problem. Basically, I have set up a flow system (channels within a substrate) I have then set-up an inlet velocity and an out flow. The system runs fine, which is always great, however, I want to change the inlet velocity and produce a graph of velocity against temp (there is a heater attached to this system). Does anyone know how I can do this, without having to manually change the inlet velocity and run the iteration again?
G
mapuma is offline   Reply With Quote
Old   February 12, 2010, 01:28
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Switch to unsteady solver, and create a profile for your velocity inlet.
Or you can create a batch file, with something like:
rcd case1.cas
yes
it 1000
wcd case1.dat
yes
rcd case1.cas
yes
define/bc/velocity-inlet (check help for setting it with text command)
it 1000
wcd case2.dat
yes
etc...
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Multiple domains - buoy. ref. temp. setting Forrest CFX 8 February 22, 2006 13:43
applying the same setting to multiple cases Ralf Schmidt FLUENT 3 November 4, 2005 14:06
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Automating multiple runs within pre? Zheng CFX 7 February 3, 2005 15:33
Warning 097- AB Siemens 6 November 15, 2004 04:41
