Pressure evaluation at certain points
Old   March 1, 2010, 05:23
Default Pressure evaluation at certain points
Feitan is on a distinguished road
Hi everybody, I’m trying to solve a simple problem to which I haven’t found a solution yet. I hope you can help me. I have an object, let’s say a Frisbee. I measured the value of the static pressure in a wind tunnel by means of a precise number of probes properly placed on the Frisbee. Now I run the simulation within Fluent and I’d like to know the value of the static pressure at the probe coordinates (which are known). Do I have to create a huge number of “point-surface” (about 150) or is there a easier and smarter way to obtain what I want? Thank you very much.
Feitan is offline   Reply With Quote
Old   March 1, 2010, 11:44
Default Use of txt commands to write ajournal file
tony00 is on a distinguished road
Hi
I would suggest to write a journal file you can feed to Fluent.
File-> Read-> Journal
To find the appropriate txt command for the journal file a quite conveninet way is to hit the enter key so that Fluent shows you the available options.
If the instructions in your journal file are repetitive you can write the journal file with a scripting language. I use perl.
Tony
tony00 is offline   Reply With Quote
Pressure boundary conditions hiras FLUENT 22 July 27, 2015 01:38
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
