-   -   define a water-salt solution in fluent (http://www.cfd-online.com/Forums/fluent/73014-define-water-salt-solution-fluent.html)
arashmarahel180 February 24, 2010 09:35
Hi everybody
does anybody know how to define a water-salt solution in fluent?
thanks
coalgas February 26, 2010 09:10
hello,
to define salt-water solution, You need to select fluid species Water [H2O(l)]. Then, you need to create pseudo species named Salt, with similar properties.
Now, create Mixture named Solution, then add water and salt in as species. Now, to adjust % of salt in the solution you need to specify H2O value in the solution panel by 'patch'. i hope, this will be helpful to set up Salt-water solution.
regards
Chetan
arashmarahel180 February 27, 2010 04:45
thanks a lot
u solve my problem
georgeegro January 26, 2012 06:31
hello,
I have already had the same problem. Could you help me How I can define water-salt solution for fluent. I havent understood the procedure below. Pls HELP ME!!!
