Error with the unsteady flamelet Model
Old   February 25, 2010, 11:06
Default Error with the unsteady flamelet Model
Christoph_84 is on a distinguished road
Hallo,
i want to use the unsteady flamelet modell for natural gas combustion. First I tried the GRI 3.0 mechanisem, this work fine. Now I use the san diego mechanisem. The steady flamelet model works, i can initialise the unsteady model, but get the error:
Warning: Species XX not in flamelet-mixture.
but when I create the flamelet-mixture the species is included.
Reading volumetric reaction mechanism file ...
Done.
Reading volumetric thermodynamic database file ...
Done.
Reading transport property database file ...
Done.
Material n2:
Changing method of "Thermal Conductivity" to "constant" -- data required.
Changing method of "Viscosity" to "constant" -- data required.
Material o2:
Material flamelet-mixture:
Warning: Enabling the unsteady solver.
Disabling all equations except Unsteady Flamelet Probability.
The Unsteady Flamelet model requires the unsteady post-processing
of a probability equation on a steady, converged laminar flamelet
solution.
Updating solution at time level N... done.
Calculating Unsteady Flamelet at Scalar Dissipation 9.29/s
Warning: Species o2 not in flamelet-mixture.
Warning: Species hoso2 not in flamelet-mixture.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Interrupting...
Done.
Christoph_84 is offline   Reply With Quote
Reaction Rate (wk) on Flamelet model AdidaKK CFX 2 November 17, 2009 17:54
second and final question about flamelet combustion model AdidaKK CFX 0 October 17, 2009 07:25
the 2 equation of flamelet model. AdidaKK CFX 0 October 17, 2009 05:33
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
Tets and k-e model for unsteady turbulence flows Jen Main CFD Forum 0 July 9, 2003 13:28
