Home > Forums > FLUENT
mass/heat transfer in Fluent
Old   March 1, 2010, 09:06
Default mass/heat transfer in Fluent
ck3
Khaled
ck3 is on a distinguished road
Hi anybody!
I'm new in Fluent and I want to simulate a turbulent heat and mass transfer in wavy wall.
How to lunch mass transfer modelling in fluent?
ck3 is offline   Reply With Quote
Old   March 1, 2010, 12:38
Default Procedure for CFD analysis
tony00 is on a distinguished road
you need to proceed in this way:
1) build your geometry in either gambit or icem
2) mesh it
3) export the mesh
4) read the mesh in fluent
5) run the simulation
6) check your results
I would suggest to start with gambit tutorials, then fluent tutorials.
Tony
tony00 is offline   Reply With Quote
Old   March 1, 2010, 12:52
ck3
Khaled
Dear tony00,
Thank you for your answer,
I already treated some example with Fluent.
for this case, I have already do everything (building the geometry, exporting the mesh ....) but the problem it is how to make for mass transfer.
Old   March 1, 2010, 13:22
Default Mas transfer
you need to specify your problem a bit if you want some help. It is not clear to me what you mean.
All the best
Old   March 1, 2010, 17:34
ck3
Khaled
Dear tony00,
Firstly, I launched a simulation to validate the commercial code Fluent in 2D and 3D (steady and unsteady) and I compared my results with those of Maaß and Schumann and I had very good results.
http://cfd.mace.manchester.ac.uk/cgi...as77_rsol.html
Now, I want to see the effect of wave amplitude (various amplitudes) on heat and mass transfer.
Old   March 1, 2010, 18:20
Smile
aounallah is on a distinguished road
hi Khaled
it me aounallah,
I think that you need to concentrate only on mass transfer (the thermal transfer is quite easy to you to do it )
you can refomulate your question asking how to simulate only the mass transfer in a simply 2D geometry (fluid, procedure,steps)
good luck , I will inform you if I found something in this field
aounallah is offline   Reply With Quote
Thread Tools
Trackbacks are On
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Mass Transfer Model in FLUENT Saturn FLUENT 3 March 2, 2010 05:17
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 13:31
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
How does FLUENT fair in absolute heat transfer analysis Steve Aboagye Main CFD Forum 1 August 31, 1998 12:12
