September 28, 2004, 10:40 |
read geometry from Fluent
I have only .cas and .dat files which have been worked a few years ago by FLUENT. (These were not my work) Can I read the geometry of these files in GAMBIT? I want to analyse it and know how it has been build. Thanks!
September 28, 2004, 13:01 |
Re: read geometry from Fluent
If you have the .cas file, you can use the import command in gambit. Select file/import/mesh. and the select the appropriate type of mesh (eg. fluent 5/6), then select the .cas file and gambit should import the mesh. I hope this helps. Good luck
September 30, 2004, 07:03 |
hi, i tried the method what you told. but it is not exporting. i am using 6.0.2. it is saying that unable to import the file
venu |
October 1, 2004, 09:07 |
are you reading in a .cas file? In gambit make sure you select file/import/mesh and then select fluent5/6 then make sure you select the appropriate dimensionality (2-D/3-D)
March 14, 2018, 08:40 |
chaimaa
well, you can read .cas & .dat files in CFD Post, you can use this software to export information from your files and do data treatement.
Good luck with that |
March 9, 2021, 02:29 |
desiccant wheel
amir
hi
I need the geometry of the desiccant wheel by ansys to do a sizing |
Read ASCII into FLUENT | Fabio | FLUENT | 2 | September 26, 2022 18:25 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
How to read or write case by commands during simulation with Fluent | lzgwhy | FLUENT | 4 | April 20, 2011 22:02 |
FLUENT can not read data file | jing113cn | FLUENT | 0 | December 6, 2010 09:06 |
Import Soliworks geometry to Ansys Fluent 12.0 | nunolopes | FLUENT | 0 | October 7, 2010 11:24 |
