meshing sharp edges-how to do it?
Old   March 2, 2010, 23:37
Default meshing sharp edges-how to do it?
Sri
sripriyarajendran is on a distinguished road
I am simulating a multiphase hydrocyclone flow(VOF simulation). There is a solid rod at the centre, where the air core is generally present. the rod is placed at some distance below the VF. The air core as in the normal cyclone starts from the VF and moves inwards. as it touches the rod the flow diverges. Any special precautions necessary for meshing around the sharp edge of the rod?
sripriyarajendran is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
meshing sharp edges Ralf Schmidt FLUENT 2 April 6, 2015 09:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
error meshing edges sivaraja ANSYS Meshing & Geometry 1 June 19, 2009 10:09
Boundary layer meshing with sharp trailing edges Andrew Berner FLUENT 1 August 28, 2007 17:39
