Home > Forums > FLUENT
Urgent---Heap Limit Reached---how to Rectify
Old   March 3, 2010, 03:35
Thumbs down Urgent---Heap Limit Reached---how to Rectify
Ankit Gupta
ankitgupta_vit is on a distinguished road
when im running my iteration...it is showing an error msg in fluent window that:
"Error: heap limit reached. Cannot allocate additional chunks.
Error Object: () "
plz tell me how to go abt it..
ankit gupta
IISc, bangalore
ankitgupta_vit is offline   Reply With Quote
Old   March 10, 2010, 02:22
Andrew
Andrew is on a distinguished road
Hi Ankit,
I have recently come across the same error message in Fluent. I found that it has to do with Fluent's memory.
Particularly, the amount of I/O from the software during simulations. Check how much monitors you are running and how many data sets you are saving during the simulation. You will need to reduce the amount of monitors and/or data sets and run the additional sets again later.
Fluent seems to have errors saving the monitors and keeping the memory in storage, so you need to select only key monitors and data recording. Once the simulation has finished, you can run it again, or continue the simulation, but this time with the other monitors instead. Keep the amount of I/O to a minimum.
Regards
Andrew
Andrew is offline   Reply With Quote
Old   March 10, 2010, 03:42
Default Heap limit
Ankit Gupta
@Andrew---thank you for your valuable suggustions...
Old   March 10, 2010, 03:57
Andrew
That's ok. Glad to help.
Regards
Andrew
Old   November 21, 2012, 22:52
dengjiajia
dunga82 is on a distinguished road
Originally Posted by Andrew View Post
Hi Ankit,
Regards
Andrew
Hi Andrew,
I have the heap limit reached problem when I have finished the hook of udf and want to save the cas file. The udf is used for calculation but not to save and output data.
When I found your suggestion at upside, I try to switch off all of monitors, but the problem still occurs here.
I have no idea at this moment, could you please give me some ideas?
dunga82 is offline   Reply With Quote
Thread Tools
Trackbacks are On
transient limit is 99,999 time steps? URGENT azmir CD-adapco 2 April 15, 2007 22:06
Fluent error: Heap limit reached mike FLUENT 2 April 12, 2007 23:41
