Home > Forums > FLUENT
How to Patch?
Old   March 9, 2010, 01:50
Default How to Patch?
chinc is on a distinguished road
Dear Folks,
I have a problem here on using patch.
Due to some constraint on computing resources, I need to break down my 3D domain into two blocks. One block sits within another. The smaller block contains complex cavities which if modeled required a high number of computational cells.
I am thinking of simulating the larger block alone first, then at the surface where it is linked to the smaller block, I wish to "pass" the flow variables, i.e. pressure to the inlet of the smaller block.
Can someone please guide me how can I use patch or other methods (if available) to identify and feed the data at the interface between the two blocks from larger to the smaller block so that I can run the simulation separately for the smaller block with higher grid resolution without being constrained by the limitation of computing resources and time.
Thx very much in advance.
chinc is offline   Reply With Quote
Thread Tools
Trackbacks are On
Using starToFoam clo OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 33 September 26, 2012 04:04
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
Import gmsh msh to Foam adorean Open Source Meshers: Gmsh, Netgen, CGNS, ... 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
