UDF species equations
Old   August 25, 2009, 05:16
Smile UDF species equations
hameurlaine
louiza is on a distinguished road
Hello all,
I would like to modeling arc discharge in argon (ideal gaz) with 6 reactions and 3 species, for this I need to solving the transport equation with source term via UDF that includes (construction species , destruction species) .
I wrote the source term = the ensemble of creation and destruction of species in an analytical form, I get a set of equations (N) with N incconu.
[dAr/dt]=k3*[ne]*[Ar]+k4*[ne]*[Ar*]+.........
[dAr*/dt]=k2*[ne]*[Ar]-k4*[ne]*[Ar*]-.........
[dAr/dt], [dAr*/dt]: molar concentration of atom of argon, and excited atom of argon.
k2, k3 : rate reaction2 and 3 depend of electronc temperature.
k4 : rate reaction (4) is constant.
The reaction rates depending on the electron temperature and there are some constant.
How do I solve this set of equations and if you have any UDF examples for species equations please let me send.
please help me
Thank you!
louiza is offline   Reply With Quote
Old   August 29, 2009, 04:43
bgu
bgu is on a distinguished road
Originally Posted by louiza View Post
Hello all,
please help me
Thank you!
Please look at the FLUENT 6.3 UDF manual chapter 2.3.22
If it not available to you, I copied the relevant example which deals with
two reactions.
Instead of the lines /*Reaction xx*/ put your own reactions and replace the
reaction names in the example with your names in the Reactions panel.
Finally, after compilation, make it available in the UDF hooks panel under
Volumetric Reaction Rate,
Multiple reaction UDF that specifies different reaction rates
for different volumetric chemical reactions
#include "udf.h"
DEFINE_VR_RATE(myrate,c,t,r,mw,yi,rr,rr_t)
/*If more than one reaction is defined, it is necessary to distinguish
between these using the names of the reactions. */
if (!strcmp(r->name, "reaction-1"))
/* Reaction 1 */
else if (!strcmp(r->name, "reaction-2"))
/* Reaction 2 */
else
/* Message("Unknown Reaction\n"); */
/* Message("Actual Reaction: %s\n",r->name); */
bgu is offline   Reply With Quote
Old   August 31, 2009, 05:52
Thumbs up
hameurlaine
Thanks a lot !
Old   February 4, 2010, 17:56
Default Yes, but the detail is not clear
Michael McMaster
elmcmaster is on a distinguished road
hi BGU and louisa, i am doing similar, catalytic reactions in packed beds, which require non power law rate equations to be written.
I had figured out that i need to write a UDF for this before looking at this thread, but if i have say three components involved in the reaction how do i specify these in the rate equation in the UDF, is it based on the species mass fraction index, yi, from the header:
DEFINE_VR_RATE( name,c,t,r,mw,yi,rr,rr_t)
So essentially the first is y1, the second is y2 and the third is y3?
I suppsoe i should try this before asking, but couldnt help myself.
Any guidance will be greatly appeciated.
Michael
elmcmaster is offline   Reply With Quote
Old   March 10, 2010, 01:20
Byron Smith R J
byronsmith is on a distinguished road
hai
the order of Yi comes from the order of listing the components and it starts with 0 and not 1. get the massfractions and then convert them into required terms to use in hte rate of reaction equation
byronsmith is offline   Reply With Quote
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
UDF for species mass fractions MRR FLUENT 0 December 29, 2005 07:14
Retrieving species in UDF Fernando FLUENT 0 September 3, 2004 08:22
UDF and PDF species mass fractions Ale FLUENT 0 July 18, 2003 09:04
UDF reading species data of pdf simulations Jamiro FLUENT 0 June 20, 2001 17:15
