March 16, 2010, 10:45 |
Wave equation for hfss in fluent
Rep Power: 16 |
Im trying to simulate the electromagnetic field in the frecuency domain solving the equation laplac(phi)+k^2*(phi)=0. Im trying to view the effect of the drying of building materials via microwave sources (cm long wave). To do this im trying to use a used defined scalar with a source term depending on the velocity without convenction term. Im not sure if this is possible with fluent The problem a cant get the sinnousoidal pattern that supose to be solution of this equation. Im working with a 3d domain with noflux surrounded and two boundaries with the flux calculated from the exact solution. If i work with k arround 1 and no derivarive of the source term the solution explotes and if i put a derivative term the solution goes like a decay function (not phisical i think). The question is if this can be possible. CAn i calculate HFSS in fluent or CFX using adtional variables. I know that i can use potencial teory but my domain is much bigger than my wave lengh so this doesnt cover. I hope anyone can help me to solve this complicated high frecuency fields. On the other hand im planning to use ANSYS clasical and calculate the volume heat source from the electromagnetic field and import it in the CFD code. Thanks. |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
wave generation in fluent | Harry | FLUENT | 3 | August 26, 2013 00:32 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
Can FLUENT solve our own defined equation? | lily | FLUENT | 1 | April 10, 2004 18:31 |
Fluent equation error?!? | TOM | FLUENT | 6 | July 15, 2002 03:24 |
