Is it possible the velocity profile changes in the fully-developed turbulent flow? |
July 9, 2020, 16:25 |
Chen
Rep Power: 5 |
Hello, I am a new one in Ansys Fluent, and have a question now. I want to know: for a fully-developed turbulent flow, is it possible that the velocity profile changes along horizontal axis?
the model is the air flows in a pipe. First of all, for laminar flow, I input the parabolic equation at the inlet, and then the velocity profile of the laminar flow does not change, which is a fully-developed flow. For the turbulent flow, I input the same parameters and equation from the laminar flow, just change the viscous from laminar to k-ε standard. But this time, the velocity profile of the turbulence flow changes, unlike the laminar flow. I want to know is it possible that the velocity profile changes for a fully-developed turbulent flow? If possible, why changes? If impossible, which means the velocity profile should be constant, so how to set up a fully-developed turbulence flow with constant velocity profile? I have also put the details in the pictures, thank you! |
fully-developed, pipe, turbulent flow, velocity profile |
1-D Fully Developed Turbulent Pipe flow | RruffPaw | Main CFD Forum | 7 | January 17, 2020 06:03 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet | Taz-CFD | ANSYS | 0 | February 19, 2016 07:49 |
Field function - Fully developed flow profile for a square micro channel | smorls | Main CFD Forum | 5 | April 9, 2015 11:01 |
Fully developed flow in Star-cd | SMM | STAR-CD | 3 | September 9, 2011 15:54 |
