-   -   heat transfer probs by transonic flow (http://www.cfd-online.com/Forums/fluent/73924-heat-transfer-probs-transonic-flow.html)
Josh_Blue March 19, 2010 14:05
Hi all,
I am simulating the heat transfer between a sphere and its environment by subsonic and supersonic incident flow in 2D. Furthermore the flow shall be compressible.
Here some key data:
- sphere BC: wall, no slip and constant temperature
- inlet BC: pressure far field
- outlet BC: pressure outlet
- density based solver steady state
Now, I'm dealing some problems by simulating the transonic flow (0.8<M<1.4). Despite of good convergence (except of M=1.3 and M=1.4) the contour plot of velocity magnitude is really strange. The other ranges like 0.4<M<0.8 and M>1.4 meet my expectations both in convergence and contour plots.
So what am I doing wrong? Should I maybe run the simulation now unsteady or do I have to take sth. else into account??
Any suggestions and answers are welcome! Thanks in advance!! :-)
sega March 19, 2010 14:29
Turbulence?
Josh_Blue March 20, 2010 07:01
oh sorry, I forgot to mention: No, it's laminar...
sega March 20, 2010 09:22
I'm no expert, but can a transsonic flow be laminar?
Josh_Blue March 20, 2010 16:57
why not? I am not an expert as well, but I was thinking that there is no problem running a transonic and laminar simulation...
sega March 20, 2010 17:43
Depends on your Reynolds number. Can you tell us what it is?
Josh_Blue March 20, 2010 18:11
well, since the sphere has a diameter of 5Ám, the Reynolds number is definitly below 100 (in between of 60 and 80)..
sega March 21, 2010 04:24
Ok, this is laminar. I have no further ideas, what may be wrong.
And your solution is good in medium and high Mach numbers?
Strange ...
Josh_Blue March 21, 2010 06:31
right, low and high Mach numbers are ok, but the transonic range... :-/
