Home > Forums > FLUENT
Convergence Problem?
Old   March 21, 2010, 10:57
Default Convergence Problem?
Jérémy Bulle
Gearb0x is on a distinguished road
Hello
I'm trying to compare 2 geometries and I'm having "problems" with the 2nd one.
Here is the "round" geometry :
http://yfrog.com/0vroundnp
It converges in approxmimately 500 iterations.
Settings are : 2D, SIMPLE algorithm, pressure standard, 2nd order for all the other discretizations, k-epsilon Enhanced wall function. Y+<1 everywhere
With the "square" geometry and the same settings, it converges in approximately 7500 iterations and at the beginning I have weird things appearing for the pressure field as you can see in this screen :
http://yfrog.com/8dconvergence1p
Velocity doesn't seem to have this problem :
http://yfrog.com/5zvelocityconvergencep
And I don't understand why I have such behaviour... Could you give me some ideas?
Thanks for the help
Gearb0x is offline   Reply With Quote
Old   March 22, 2010, 02:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you have a problem with the mesh at the right side from the square geometry.
Check the connectivity from your edges over there.
You can display the default wall (without grid) and check if you don't have an edge in the fluid domain.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 22, 2010, 03:37
Jérémy Bulle
That's what I think too but I can't find the error in the mesh.
And what's most weird is that if I let fluent iterates more (say 7500 iterations) then everything seems to be ok ...
Old   March 22, 2010, 03:43
Jérémy Bulle
I defined the edges inside the canal as "interior" for the boundary condition type in gambit
Is it correct?
Old   March 22, 2010, 04:04
-mAx-'s Avatar
Maxime Perelli
you don't need to define them.
If your splits are correct, gambit sets them automatically as interior.
If you need to define them, then there is a problem.
Click and click and click on the edge, and check how many edges are picked. If there is more than one, then you have superposed edges.
Old   March 22, 2010, 05:04
Jérémy Bulle
Again thanks for the help
I checked egdes in gambit : I deleted edges to see if there were more than one and there was only one edge so no problem here apparently
Thread Tools
Trackbacks are On
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
