DPM Injection problem
Old   March 22, 2010, 03:26
Default DPM Injection problem
S.M.Sumon
mesumon203 is on a distinguished road
Hello Everyone,
I am trying to make a simulation using DPM Method. But here i am feeling some problem. can anybody please help me by sayinh how can i change the direction of the INJECTION.now the injection is going towards the opposite side with expected.
mesumon203 is offline   Reply With Quote
Old   April 4, 2010, 22:38
李逾
yubaibai88 is on a distinguished road
Originally Posted by mesumon203 View Post
Hello Everyone,
what kind your injection type is .
for example if set the type group,under point properties,you can set the opposite velocity.it will change the inject direction.
yubaibai88 is offline   Reply With Quote
Old   April 4, 2010, 23:03
S.M.Sumon
Thanks for reply.
i am trying to set a solid cone injection. and one more thing can you please tell me how can i reduce the temperature using the solid cone injection i mean in point properties which property is relevant for reducing temperuatre
Old   April 4, 2010, 23:09
李逾
Thanks for reply.
I don't understand what you mean.
generally I set temperature in BC
Old   April 4, 2010, 23:15
S.M.Sumon
ya i also set it now i want to reduce the inner high room temperature with injection. so what point properties are important like mass flow rate or velocity
because my temerature is not changing with injection
Thanks
Old   April 4, 2010, 23:21
李逾
Thanks
you mean you want to find out the max factor to the surround temperature while discrete particle are injecting into the area?
Old   April 4, 2010, 23:24
S.M.Sumon
yes i am trying to reduce the temperature with injection of water bt actually the temperaure of the heated zone is not reducing. so i think i am missing some properties so can u tell me what or which properties are importan for reducing temperature
Old   April 4, 2010, 23:27
李逾
did you enable the energy equation
Old   April 4, 2010, 23:31
S.M.Sumon
yes i set the high temperaure in the b .c and the interior zone is gets heated because of the heated zone now with water spray injection i wanna reduce the temperature so what point properties are necessay
or do u know about any tutorial related to fire supprssion with vertically downward sray or related.
Old   April 4, 2010, 23:43
李逾
sorry,I do not have some tutorials about fire,I got some about combustion from fluent,tell me your e-mail if you need
Old   April 4, 2010, 23:44
S.M.Sumon
mesumon203@yahoo.com
thanks for your help.
Old   April 4, 2010, 23:56
李逾
mails has been sent
tell me if you receive it
Old   April 5, 2010, 04:34
S.M.Sumon
mails has been sent
yes i found it. thanks brother
DPM converging Problem Markus Alzon FLUENT 6 April 7, 2016 11:41
Interesting Injection result of DPM? Rachel FLUENT 2 July 8, 2008 18:00
DPM uncoupled display problem K. Jagus FLUENT 0 July 7, 2005 03:06
DPM, UDF, Injection Type Zhang FLUENT 0 June 8, 2005 15:51
how to do with the DPM problem? x.p.lee FLUENT 1 June 26, 2003 13:07
