error information for Maro P_USER_REAL(p,0)
I tried to use Macro P_USER_REAL. The following code is from UDF user manual. DEFINE_DPM_SCALAR_UPDATE(dpm_scalup,c,t,if_init,p) { if (if_init) P_USER_REAL(p, 0) = 0; /* Simple initialization. Used later for stopping trajectory calculation */ } However, I got the error information as follows: Signal received: Signal 0 - None Traceback: Location 0x0000000000000000 --- End of call chain --- EOF on command stream. The fluent process could not be started. Can anyone know what is the cause for the error? Thank you. |
