about VOF and evaporation
Old   March 28, 2010, 07:16
Unhappy about VOF and evaporation
mengyue
mengyue1 is on a distinguished road
Hi guys, i am confused about my work now.
the question is: water falls down along a vertical heated tube (falling water film) to cool the tube, meanwhile, air is forced into the tube from the bottom of the tube to enhance the evaporative effect of the falling water film.
i use VOF model to track the interface of gas phase and liquid face, as for evaporation, i found udf in some website, but it just involves water and steam, so how i write udf to introduce the mass of vapor to the air, i mean, in my case, there are two kinds of gas in the gas phase, how i treat them using VOF? or maybe VOF dosen't work for this case?
thanks a lot!
Regards!
mengyue1 is offline   Reply With Quote
Old   March 28, 2010, 08:57
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
thanks a lot!
Regards!
VOF is isothermal and does not involve the energy equation.
Makeing VOF work with evaporation is no easy task.
Besides including the energy equation you will have to introduce temperature dependend mass sources / sinks for your different phases.
Which are only active on the interface.
Why do you have two gases? You just talked about water and air.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 28, 2010, 09:42
mengyue
I mean,two gases are vapor and air....as for my case, do you have some suggestions? thanks!
Regards!
Old   March 28, 2010, 11:18
sega's Avatar
Sebastian Gatzka
Well, I can't give you some useful suggestion.
Be aware that this is a very complex problem and you will have to take very much phyical laws into account.
There is a rather complex discussion in the OpenFOAM-forum about VOF and evaporation. This may be not applicable to FLUENT - as you don't have access to the code - but I'm sure you can learn a lot of things about what the problems are when facing evaporation.
Old   March 29, 2010, 00:16
mengyue
OK,thanks you all the same. i will do my best to solve this problem...
Old   April 7, 2015, 19:08
Mustafa Kadhim
Mak mak is on a distinguished road
Hi Mengyue
Did you solve your problem? if yes, can you help me in simulating the heat and mass transfer in the falling liquid film over vertical surface with an air flow? (the temperature of the vertical surface is kept constant below the saturation temperature of the water)
Mak mak is offline   Reply With Quote
VOF simulate interface motion during evaporation ellen peng FLUENT 1 February 11, 2021 06:58
Modeling evaporation along free surface (VOF) sandeshsd ANSYS 1 February 17, 2010 06:24
evaporation multiphase model ( vof? mixture ? ) emanuele FLUENT 0 March 2, 2007 11:44
evaporation in vof asghari FLUENT 3 May 27, 2006 02:58
evaporation and condensation in the VOF model Glev FLUENT 0 December 24, 2004 04:55
