Water turbine - TSR/power
3 Attachment(s)
I am working on a turbine problem.
I have been trying to get the power extracted by the turbine. Initially I had meshed in ICEM CFD with tetra/prism meshing. I ran the simulation in Fluent. My settings are as follows Solver Pressure based, velocity formulation absolute, steady Viscous SST k-omega turbulence model Moving reference frame The turbine is to rotate in clockwise direction as viewed from inlet about x axis, hence given a negative rotational velocity in the cell zone condition(as viewed from the moving reference frame) Boundary conditions Inlet – inflow velocity (constant along positive x axis), reference - absolute Outlet – pressure outlet with a gage pressure of 1 atm (2 atm absolute pressure) , I had used massflow outlet before Symmetry – outer cylindrical domain Periodic - rotational Turbine- Wall…moving relative to adjacent cell…zero velocity Solution Method Coupled second order Solution Initialization From Inlet…Relative to cell zone Convergence criteria 10e(-06) Think everything that I have set up is right. The basic problem I am facing is I tried to calculate the power. From forces>moments I get the torque and that multiplied by rotational velocity and 3 times(for three blades) I get the power. As seen in experimental results I should get a curve of Cp as shown in the figure(increasing first and then decreasing after a peak). Instead I get Cp which is ever increasing with increasing TSR(tip speed ratio = (rotational velocity* radius)/stream velocity)), even going above 1(ideally should not go above 0.6). I have increased the TSR by fixing the inflow velocity and changing the rotational velocity. Now, I have tried blocking using ICEM and run the simulations in the same fashion(because I thought the mesh is an issue). I still get the same results. Would like to know why these erratic results are coming up. Somebody please help. |
