reverse flow and divergence in AMG solver
reversed flow in 24 faces on outflow 43.
reversed flow in 25 faces on outflow 55. temperature limited to 1.000000e+000 in 13 cells on zone 31 in domain 1 temperature limited to 5.000000e+003 in 11 cells on zone 31 in domain 1 temperature limited to 1.000000e+000 in 5 cells on zone 32 in domain 1 temperature limited to 5.000000e+003 in 3 cells on zone 32 in domain 1 temperature limited to 1.000000e+000 in 1300 cells on zone 34 in domain 1 Error: Divergence detected in AMG solver: uds-0 Error: Divergence detected in AMG solver: uds-0 Error Object: #f ******************************* WHY????? |
I would first check the grid where you're hitting the solution limits. Maybe the cells are highly skewed, or there is a sharp edge?
hi
i am agree by th following answer. i encounter to this problem as u i solved it by increasing the mesh density.
