Dpm
Old   April 1, 2010, 04:00
Default Dpm
Mohsin Mukhtar
Mohsin is on a distinguished road
How can i initialize the the injection particles once i calculate the particle tracking in DPM modeling. Please guide
Thanks
Mohsin is offline   Reply With Quote
Old   April 1, 2010, 17:20
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
You can't track them without injecting / initializing them.
So, what do you want?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 2, 2010, 01:18
Mohsin Mukhtar
Ya i Know that. What i meant was that once i calculate particle track it gives me summary of the particle tracks that these zones have this much of particles trapperd etc. But when I press the track button again it gives me different values in summary. why is it doing like this? Do i need to initialize the injected particle and then press the particle tracking? I m really confused./ I hope i made you understand about my problem and I also hoe that you may have a solution to this...
Old   April 2, 2010, 06:04
sega's Avatar
Sebastian Gatzka
You will not have to initilize the particles in the way you intitalize the field values.
Where do your particles start from?
What kind of injection do you use?
Old   April 3, 2010, 10:11
Mohsin Mukhtar
Thank you Saga
Actually i got my answer. I was getting different results. that was because of stochastic tracking which i had enabled for turbulence of the particles. What stochastic tracking does is that it assumes values which are different in every case thats why it was giving me difffernt values.
i was using surface injection. and particles strat from upper inlet into the cylinder.
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM post proc problem Stel_K FLUENT 1 March 27, 2009 09:42
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
