reverse colormap
Hi!
is it possible, to reverse the colour map? I am using the gray map, that is from dark (low values) to bright (high values). But, I want it the other way round (to fit with the literature I compare). How to reverse the colourmap????? Thanks! Ralf |
You can switch the min and max value in the plot setting if you want to reverse the color map. Thanks |
