February 3, 2010, 02:43 |
Moving mesh problem
Geon-Hong Kim
Rep Power: 16 |
I tried to analyze a shrouded propeller with moving mesh.
I tested FLUENT 6.3 under both x64 CentOS Linux and WinXP professional edition(32bit). After I set up the problem to solve it with moving mesh, I checked the grid but no problem was occurred. However, when I started to iterate with unsteady solver, then I encountered following error messages... Code:
WARNING: non-positive volumes exist. divergence detected in AMG solver: pressure correction Primitive Error at Node 5: floating point exception I also tried to solve the problem with same setting but stationary mesh, there was no problem like this at all. When I set an moving mesh for an open propeller, there was no problem too. Why this happened and what should I do? |
February 3, 2010, 22:09 |
Mas
Rep Power: 16 |
for the non-positive volumes problem, you should check your remeshing settings, eg. min/max length scale and size remesh interval.
<Mas> |
February 7, 2010, 00:44 |
AMG solver
Elahe
Rep Power: 16 |
Hi Geon
did you solve your problem? I countered with this error too, I change factors of solve but i do not get results. thanks in advance. elahe |
April 5, 2010, 03:24 |
Geon-Hong Kim
Rep Power: 16 |
Dear ekakavand
Just made grid again and now I have no problem with my computation. Sincerely, Geon-Hong |
moving mesh, non-positive volumes |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
problem related to mesh | naveen | CFX | 3 | March 25, 2006 08:47 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Moving Mesh problem | Sabe | Siemens | 0 | February 12, 2004 07:41 |
Moving mesh problem | Jan Majer | Siemens | 2 | June 10, 2003 04:19 |
