URGENT help required regarding UDF operations in Fluent
Hi y'all,
I created my model using Icepak for a transient test case. I read the .cas file in Fluent and tried to "Interpret" the udf file and got the following error: g++ -I"/usr/local/fluent/Fluent.Inc/fluent6.3.26/src" -I"/usr/local/fluent/Fluent.Inc/fluent6.3.26/cortex/src" -I"/usr/local/fluent/Fluent.Inc/fluent6.3.26/client/src" -I"/usr/local/fluent/Fluent.Inc/fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "Transient_test00.udf.c" Transient_test00.udf.c: In function âvoid udf_func_1(Thread*, int)â: Transient_test00.udf.c:13: warning: deprecated conversion from string constant to âchar*â Transient_test00.udf.c:14: warning: deprecated conversion from string constant to âchar*â /usr/lib/gcc/x86_64-linux-gnu/4.4.1/../../../../lib/crt1.o: In function `_start': /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:109: undefined reference to `main' /tmp/cck1fbPE.o: In function `udf_func_1(thread_struct*, int)': Transient_test00.udf.c:(.text+0x6b): undefined reference to `RP_Get_Float(char*)' Transient_test00.udf.c:(.text+0x82): undefined reference to `RP_Get_Float(char*)' collect2: ld returned 1 exit status Error: "Transient_test00.udf.c": line 1: syntax error. Any suggestions? Thanks, Prashaanth |
