Simulation of Water Flow through a Venturi Meter
Old   January 30, 2008, 07:41
Default Simulation of Water Flow through a Venturi Meter
Hassan A
Hello All,
Having some problem calculating and comparing the pressure difference upstream and downstream of the venturi plate. Please, any advice?
Old   January 30, 2008, 09:04
Default Re: Simulation of Water Flow through a Venturi Met
Ramesh.K
Hey Describe ur problem then only you can expect help
Old   April 7, 2010, 06:00
Default question
balazs b
balazs1111 is on a distinguished road
I have similar problem with the pressure difference. I have a pipe something like this:
......_______________
inlet|......_........|.outlet
.....|_____/ |_______|.
I have everything, the size of the model, the 2d mesh, the property of the fluid, flowrate etc...
After running the simulation in FLUENT, how can I calculate the pressure difference 25mm upstream and downstream of the plate?
What are the 25mm upstream and downstream of the plate?
Thanks for any answer
balazs1111 is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
calculate volume flow from a 2D simulation SimonH. OpenFOAM 0 October 27, 2009 04:39
problem of river flow simulation Liu Main CFD Forum 0 May 27, 2004 22:01
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
