-   -   Running Fluent on remote Unix server (http://www.cfd-online.com/Forums/fluent/74985-running-fluent-remote-unix-server.html)
msth April 13, 2010 15:29
I got error on running parallel fluent on a cluster. I tried to run my case file by command
Fluent 3ddp -g -t8 < myinput.txt > myoutput.txt &
but getting error. This is myinput file
file
rc Moving30L-ke9309.cas
rd Moving30L-ke9309.dat
/solve
initialize
initialize-flow
/solve
set
time-step
0.00001
/solve
dual-time-iterate
20
20
/file
wc Moving30L-ke9329.cas
wd Moving30L-ke9329.dat
exit
yes
I run before my case file on my PC and I wanted to test it by 20 more time-steps.
Your help is appreciated.
Best,
Msth
Chris D April 13, 2010 16:05
What is the error message?
msth April 13, 2010 16:26
Dear Chris
Thanks for replying.
Actually, I used the above file as input file for my batch file. Below is the part of output file for error.
/file>
/file> invalid command [read-data]
/file> auto-save/ read-case-data start-journal
binary-files? read-field-functions start-transcript
confirm-overwrite? read-journal stop-journal
define-macro read-macros stop-macro
execute-macro read-profile stop-transcript
export/ read-transient-table write-cleanup-script
import/ set-batch-options write-field-functions
read-case show-configuration write-macros
/file>
/file//solve>
/file//solve/initialize>
/file//solve/initialize> compute-defaults/ list-defaults
initialize-flow set-defaults/
/file//solve/initialize//solve>
/file//solve/initialize//solve/set> invalid command [time-step]
/file//solve/initialize//solve/set> invalid command [0.00001]
/file//solve/initialize//solve/set> bc-pressure-extrapolations limiter-warnings? reporting-interval
disable-reconstruction? limits residual-verbosity
discretization-scheme/ multi-grid-amg set-controls-to-default
equations/ multi-grid-controls/ slope-limiter-set/
expert numerics surface-tension
flow-warnings? p-v-coupling under-relaxation/
gradient-scheme relaxation-method
/file//solve/initialize//solve/set//solve> invalid command [dual-time-iterate]
/file//solve/initialize//solve/set//solve> invalid command [20]
/file//solve/initialize//solve/set//solve> animate/ iterate patch
execute-commands/ monitors/ set/
initialize/ particle-history/
/file//solve/initialize//solve/set//solve//file>
/file//solve/initialize//solve/set//solve//file> auto-save/ read-case-data start-journal
/file//solve/initialize//solve/set//solve//file> invalid command [exit]
/file//solve/initialize//solve/set//solve//file> invalid command [yes]
/file//solve>
/file>
> Halting due to end of file on input.
job finished at Tue Apr 13 10:32:14 PDT 2010
I can email you my batch and whole output file if you need it.
