Laminar flow and roughness in fluent??
Old   April 16, 2010, 14:42
Default Laminar flow and roughness in fluent??
milos
1000sh is on a distinguished road
Hi all I was just wondering if its possible to model roughness with a laminar flow. I have managed to model roughness with a turbulent flow by using the k-epsilon model and setting the near wall treatment as standard wall functions. This has meant that I could define the roughness in the wall boundary conditions.
I was wondering if you could do the same with a laminar flow? If i select the laminar model I cannot define the momentum wall boundary conditions. Can I use the k-epsilon model and have a laminar reynolds number? will it yield the correct results or would they be wrong?
thank you!
1000sh is offline   Reply With Quote
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
Modelling roughness with a laminar flow in Fluent 1000sh Main CFD Forum 0 April 16, 2010 14:41
Roughness in Turbulent Pipe Flow 1000sh FLUENT 2 April 11, 2010 05:55
Surface roughness in laminar flow carno FLUENT 4 August 19, 2007 15:52
Pipe Roughness in Laminar Flow Swarup FLUENT 1 October 7, 2005 09:40
