Home > Forums > FLUENT
Rotating a sphere
Old   May 4, 2010, 09:22
Rick
RiKR0K is on a distinguished road
By that you mean drag and lift? I only have that in the monitors option, I don't have spin vector, drag is in x=1 and lift is y=1
Originally Posted by jack1980 View Post
Have you set the direction of the spin vector and lift vector perpendicular?
RiKR0K is offline   Reply With Quote
Old   May 4, 2010, 09:36
Jouke de Baar
jack1980 is on a distinguished road
In the boundary condition panel you can set something like spin vector or spin axis orientation? If for example cd is in x-direction and spin axis is in y-direction (which you should check) then cl should be in z-direction.
jack1980 is offline   Reply With Quote
Old   May 4, 2010, 11:07
Rick
I put an image of the orientation of the mesh attached
In the boundary condition for the ball:
I have motion rotational and then a rotation-axis origin which I defined 0 for x,y,z
and I have rotation-axis direction in which I have 0 for x,y and 1 for z.
In the monitors I only have active the residuals, drag and lift. In the drag I have Force vector x=1 and in the lift I have force vector y=1,
I think it's ok...
Old   May 4, 2010, 11:15
Jouke de Baar
Yes that should be ok.
Hmmm ... this is strange ...
Could you perhaps upload your case somewhere, such that I can have a look at it?
Old   June 15, 2010, 06:51
Rick
I have a question regarding the Magnus (or lift force) it's about the expression that is used to calculate the Magnus force, I've found 2 of them and don't know which is the right one
is it:
Fl=1/2*cl*\rho*A*v^2
or
Fl=1/2*cl*\rho*A*r*\omega*v
I'd really appreciate the help
Old   June 15, 2010, 07:39
Jouke de Baar
They are both correct.
However the upper definition is more conventional. This will give the correct force if you use the cl from FLUENT.
Take care that A is the projected area of the sphere. ( \pi r^2 )
Old   June 19, 2010, 18:37
Rick
hello
I have another question, If you see the image I posted, it is a normal football where I did the analysis, I wanted to see more the edges and pattern, like this second image I found on the net
can anyone help?
best regards
Thread Tools
Trackbacks are On
rotating sphere boundary conditions franzisko OpenFOAM 3 October 5, 2009 07:08
Flow over rotating sphere csmistry CFX 3 August 11, 2009 19:07
udf for rotating sphere lisa FLUENT 0 March 25, 2006 15:58
help in udf regarding a rotating sphere rakesh FLUENT 0 March 23, 2006 13:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
