April 16, 2010, 14:08 |
low re k-e models/ ske with ewt
gina
please as there a difference between the standard k-e models with Enhanced wall treatement and low k-e models!
thank you to answer me |
April 17, 2010, 04:11 |
from heidar.
heidar jafarizadeh
there is some diffrences between the two models.
your question is a thematic question. low reynolds models are disigned for low reynolds and are better than common models in suphisticated situations. plz clear your requisite. thanks. |
April 17, 2010, 04:16 |
heidar jafarizadeh
enhanced wall treatment is a appropriate method for resolving the flow structure near th a wall.
in fluent for a model u can choise 3 type of wall treatment. and in fluent existed 3 version of K-e midel i recommend you to apply RNG model for computing the flow structure and behaviore. because its time consumption is a little more than STD k-e but it is better for flow prediction. now: ok we r u from? |
April 18, 2010, 13:24 |
#4 | |
gina
for the study of turbulent flow in fluent and near the wall, I use the standard ke model with enhanced wall treatment. I want to compare with Low Reynolds ke model, but with this model there is no treatment associate near the wall !? why? can this model solves the flow near the wall!? and this model must to requir specific number of cells near the wall? thanks |
April 19, 2010, 00:32 |
heidar
heidar jafarizadeh
hi gina
what is youre low reynolds model? if you choose K-e turbulence models there is three wall treatmens that could be associate by the model to resolve the near wall flow structure. if your choice is K-w the fluent automatically choose wolf stein one equation model as its wall treatment affair. the automatic choosed wall treatment in SST and STD k-w models is equal by Enhanced wall treatment in wall treat for K-e models. zero killed don't be woryy |
April 19, 2010, 09:46 |
#6 | |
gina
I will to use Abe-Kondoh-Nagano model for low reynolds ke, because i will to study heat transfer... you have not answer for my question please, why with low re ke model there is not near wall treatment?! "there will be a dead and Fluent will be the killer ... the dead will be me" |
April 20, 2010, 09:09 |
heidar
heidar jafarizadeh
dear gina
what is your fluent's version? |
April 20, 2010, 15:50 |
gina
April 21, 2010, 06:53 |
heidar
heidar jafarizadeh
be successfull
May 21, 2010, 09:48 |
ke model with EWT and low re model
gina
please I want to know, what is the diference between solving a flow with the standard ke model and enhanced wall treatement and resolving the flow with low Reynolds model?????????
February 15, 2012, 15:36 |
some differences
#11 |
heidar jafarizadeh
1- standard k-w uses wall function and your low reynolds number solve a two equation model, hence, low reynolds solution is more relieble
2- low reynolds is more time consuming because you should make the mesh dense every where 3- LRM is a modern model
Best Regards Heidar Jafarizadeh |
Implementing low Re number k-e models in Fluent. | kiran | FLUENT | 1 | July 3, 2017 17:04 |
low reynolds number models in Fluent | doug | Main CFD Forum | 6 | August 4, 2012 14:39 |
yPlusRAS in OF 1.6.x - Low Re Models | ivan_cozza | OpenFOAM Running, Solving & CFD | 0 | September 23, 2009 05:27 |
Turbulence Models for very low Reynolds Numbers | Sudhi | CFX | 1 | March 2, 2007 18:03 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
