Swirling axisymmetric buoyant plume
Hi all,
In modelling a vortex with buoyancy, the axial (vertical) velocity does not seem to be coupled with the buoyant effects despite residual convergence. Under the conditions listed below, the axial temperature difference between the plume and the surroundings reduces to near zero at about 1/3 of the domain height; it is logical that we would observe a decrease in buoyant effects. However, the observed axial velocity remains at 100% of the specified inlet value for the entire span of the domain. A reduction in the temperature differential seems to have no effect on the behaviour of the axial velocity in this regard.
What model would you recommend in order to realise the effects of buoyancy in a swirling plume? Best, Ian |
To follow up, k-omega turbulence models indeed do not account for buoyant effects on the the specific dissipation rate. For this particular case (axisymmetric buoyant jet with swirl), the RNG k-epsilon model with a swirl modification appears to be best suited.
On the standard, RNG and realizable k-epsilon models Ian |
