-   -   Flapping Wing motion (http://www.cfd-online.com/Forums/fluent/75141-flapping-wing-motion.html)
balkrishna April 17, 2010 06:03
I am doing a CFD analysis of flapping wing motion in FLUENT . For the same I have written a UDF which looks like :
#include "udf.h"
DEFINE_CG_MOTION(myudf, dt, v_cg, omega, time, dtime)
    Thread *t;
    real c=0.2;
    real omega_t=6.28;
    NV_S(v_cg, =, 0.0);
    NV_S(omega, =, 0.0);
    t=DT_THREAD((Dynamic_Thread *)dt);
    v_cg[1]=2*3.14*c*cos(omega_t*time);
    omega[2]=3.14*3.14*sin(omega_t*time)/4;
    Message("time:%f vx_cg:%f vy_cg:%f omegaz:%f \n",time, v_cg[0],v_cg[1],omega[2]);
Which is the code given in Adrien Pesenti's website . However I have troubles hooking this udf to FLUENT. My airfoil doesnt move (change its angle) when I check mesh motion under Solve-> Mesh Motion. Please can anyone help me out with this ....
Also another option is actually defining the path taken by the CG in time ..... writing a profile file .... . How does one actually write a profile file ???
almostafa67 August 3, 2010 02:13
rotation about z axis
hi dear balkrishna...
long ago you were studying a case that contained flapping wing motion, now i'm working on something like that,i sent you two images that both of them are kind of peristaltic pump,i want to rotate two/one small cylinder about z axis,i should write an udf,i've written an udf for this but does not work;I will be thankful if you could help me out
looking forward to ur help.:o
almostafa67 August 3, 2010 02:14
2 Attachment(s)
sorry I forgot to attach images;
balkrishna August 3, 2010 02:17
Yes write a UDF ... it will be simpler ... please attach the UDF ... or paste the code ....
almostafa67 August 3, 2010 02:29
dear balkrishna,it's kind of you to reply my post:)
i use the following udf
# include "udf.h"
# include "dynamesh_tools.h"
DEFINE_CG_MOTION(pump,dt,vel,omega,time,dtime)
Thread *t;
real freq_t;
NV_S(vel,=,0.0);
NV_S(omega,=,0.0);
if(!Data_Valid_P())
return;
freq_t = 4.0;
t= DT_THREAD((Dynamic_Thread*)dt);
vel[0] = 0.0;
vel[1] = 0.0;
vel [2] = 0.0;
omega [0] = 0.0;
omega [1] = 0.0;
omega [2] = freq_t;
in your opinion is that what i want,if yes what's the problem that it does not work,if not plz help me write an appropriate udf...
balkrishna August 3, 2010 02:31
what doesnt work in this ... the udf is fine .... what are the errors you are getting ?
are you getting negative volumes in the mesh ? Also use cg_vel and cg_omega for the variables vel and omega .....
almostafa67 August 3, 2010 02:34
no i mean the small circle does not rotate about center of bigger circle,i have problem in motion!
balkrishna August 3, 2010 02:35
yes ... i faced a similar problem .... use cg_vel instead of vel and cg_omega instead of omega
almostafa67 August 3, 2010 02:39
plz explain it more, how should i do it in udf,how can cg_vel rotate small circle about z axis???
balkrishna August 3, 2010 02:41
try this udf ....
# include "udf.h"
DEFINE_CG_MOTION(pump,dt,cg_vel,cg_omega,time,dtime)
    Thread *t;
    real freq_t;
    NV_S(vel,=,0.0);
    NV_S(omega,=,0.0);
    if(!Data_Valid_P())
        return;
    freq_t = 4.0;
    cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
    cg_vel [2] = 0.0;
    cg_omega [0] = 0.0;
    cg_omega [1] = 0.0;
    cg_omega [2] = freq_t;
balkrishna August 3, 2010 02:54
yes it can ....
almostafa67 August 3, 2010 03:50
dear balkrishna...
i compiled ur udf and three images that i sent u are results,as u can see small cylinder changes its position so small, i want to move center of the cylinder on the inner edge of bigger cylinder,how can i do this large displacement??
Attachment 4299
Attachment 4300
http://www.4shared.com/file/R2SbkdqT...ltic-pump.html
balkrishna August 3, 2010 03:55
i have dans guardian banning the attachment download .... read the documentation for larger displacement .... ....
almostafa67 August 3, 2010 06:08
i did not understand ur post,i had another post in mind:rolleyes:
balkrishna August 3, 2010 06:10
check the fluent docs ....
Vidit Sharma November 1, 2012 10:20
hi,
I am trying to move a 2d cylinder in y direction by using UDF:-
# include "udf.h"
DEFINE_CG_MOTION(pump,dt,cg_vel,cg_omega,time,dtim e)
Thread *t;
real freq_t;
NV_S(cg_vel,=,0.0);
if(!Data_Valid_P())
return;
freq_t = 0.01;
cg_vel[0] = 0.0;
cg_vel[1] = freq_t;
But I am having a problem while compiling it in Visual Studio Command Prompt. While executing nmake command to compile an error is appearing which is saying NMAKE : fatal error U1077: "sed" :return code '0X1'
can anybody tell how to eliminate this error???? :confused::confused:
Thank You
Regards
Vidit Sharma
balkrishna November 1, 2012 10:34
try interpreting it .... do not compile it.
Vidit Sharma November 1, 2012 10:41
Dear Sir,
I tried to interprete it but it says "line8: structure reference not implemented"
Fluent user guide also says to compile the moving mesh macros.
Thank You,
regards
moh_zain April 13, 2016 04:16
flapping wings
I am doing a CFD analysis of flapping wing motion in FLUENT and I need udf code to define the motion I do not know how to write it can any one help me with it thanks
moh_zain April 13, 2016 15:42
CFD udf code fluent
[QUOTE=moh_zain;594803]I am doing a CFD analysis of flapping wing motion in FLUENT and I need udf code to define the motion I do not know how to write it can any one help me with it thanks
