Home > Forums > FLUENT
boundary condition for compressor
Old   April 19, 2010, 07:59
Question boundary condition for compressor
Krunal
krunal_me00 is on a distinguished road
hii to all.
I am doing work on FLUENT to analyze compressor with ideal gas.
but every time i am getting reversed flow or FLUENT having fatal error.
Boundary conditions I am using are:
Inlet : Pressure inlet
Outlet : pressure outlet
Solver : Density based (steady)
Hub,Shroud and side walls : Rotating (Relative to moving ref. frame; rpm=0)
Fluid : moving ref. frame (rpm = 5000)
my actual rpm is 40000 but i want to converge it first at 5000.
i am not giving any pressure or temp values at Outlet,as it should calculate on its own.Is it right??
need urgent reply...
Thank you.
krunal_me00 is offline   Reply With Quote
Old   April 19, 2010, 12:55
Chris
Chris D is on a distinguished road
But if there is reversed flow, then FLUENT uses the backflow values that you set. If those values aren't realistic, it could blow out your solution.
Chris D is offline   Reply With Quote
Old   April 20, 2010, 01:57
Krunal
my outlet static pressure is 3.2 atm and total rpm is 40000.
if i am giving this values directly then after few iterations it shows FULENT has fatal error....
so how should i go for the solution..??
thank u..
Old   April 20, 2010, 14:56
Chris
What does it say besides "Fatal Error"? Segmentation, Access_Violation? Are you using a UDF?
Thread Tools
Trackbacks are On
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 18:07
Axis Boundary Condition..what is it? CFDtoy FLUENT 6 February 13, 2007 06:51
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 12:44
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 02:19
