Intake Flow Simulation Accuracy
Old   April 25, 2010, 05:18
Default Intake Flow Simulation Accuracy
atlantis83 is on a distinguished road
Good Morning
This is my first time in this forum and also my first time with Fluent.
I'm trying to simulate flow thoru the intake duct and valve of a gasoline engine to calculate the direct discharge coefficient with fluent and I procided in this way:
1 - mesh with workbench with y-plus between 30-300
2 - boundary condition:
2.1 - First Approach: - pressure inlet 101325 Pa total pressure
- pressure outlet 86325 Pa static pressure
this setup take to instable and non phisical solution
2.2 - Second Approach: - velocity inlet
- pressure outlet -15000 Pa relative to atmosperic pressure
in both cases I set a T.I. of 5% at inlet and 4% at outlet with relative hydraulic diameter.
As Solver i use Simple with Momentum Second Upwind and I initialize with inlet condition.
With second approach I obtain coherent values but the matching with experimental values of discharge coefficent was affected by at least 10% of relative error.
Have you any suggestion to improve the accuracy of this model??
Thank you very much.
atlantis83 is offline   Reply With Quote
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 21:39
Channel flow setup in Large-eddy simulation Weihua Main CFD Forum 6 November 17, 2015 09:33
Incompressible to compressible flow simulation Nishikant Tamrakar FLUENT 10 June 16, 2009 21:09
Stratified Oil-water Flow simulation Mijail FLUENT 2 May 18, 2009 20:20
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
