Turbulent intensity for pressure Outlet Boundary condition |
April 30, 2010, 11:19 |
Mohsin Mukhtar
Rep Power: 17 |
Can anybody tell me that how can i specify the turbulent intensity at the outlet if i dont know the velocity or any other parameter at the outlet?
In my case I have a verticle cylinder from which air is coming from the top. Pressure outlet condition requires an input of turbulent intensity and hydraulic diameter. I know the hydraulic diameter but i dont know the Turbulent intensity at the outlet. How to specify that parameter as i dont know the velocity etc at the outlet. Thanks Mohsin |
April 30, 2010, 11:36 |
Leonardo Giampani Morita
Rep Power: 16 |
These inputs are only used in case of backflow. You can simply estimate an average velocity based on mass flow rate and diameter and then estimate the turbulent intensity. If outlet doesn't differ too much from inlet, you can even impose the same values...but rememeber that if you don't expect a backflow, this won't affect your calculations
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 12:14 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 01:05 |
outlet boundary condition | neil | CFX | 1 | June 17, 2002 01:57 |
outlet massflow boundary condition ?? | Charles Renard | FLUENT | 5 | August 24, 2001 16:47 |
