Turbulent intensity for pressure Outlet Boundary condition
Like Tree1Likes
  • 1 Post By leonardo.morita
Old   April 30, 2010, 10:19
Default Turbulent intensity for pressure Outlet Boundary condition
Mohsin Mukhtar
Mohsin is on a distinguished road
Can anybody tell me that how can i specify the turbulent intensity at the outlet if i dont know the velocity or any other parameter at the outlet?
In my case I have a verticle cylinder from which air is coming from the top. Pressure outlet condition requires an input of turbulent intensity and hydraulic diameter. I know the hydraulic diameter but i dont know the Turbulent intensity at the outlet. How to specify that parameter as i dont know the velocity etc at the outlet.
Thanks
Mohsin
Mohsin is offline   Reply With Quote
Old   April 30, 2010, 10:36
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
These inputs are only used in case of backflow. You can simply estimate an average velocity based on mass flow rate and diameter and then estimate the turbulent intensity. If outlet doesn't differ too much from inlet, you can even impose the same values...but rememeber that if you don't expect a backflow, this won't affect your calculations
mahditorabiasr likes this.
leonardo.morita is offline   Reply With Quote
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
outlet boundary condition neil CFX 1 June 17, 2002 00:57
outlet massflow boundary condition ?? Charles Renard FLUENT 5 August 24, 2001 15:47
