Purpose of relaxation factors
Old   April 30, 2010, 09:08
Default Purpose of relaxation factors
Mohsin Mukhtar
Mohsin is on a distinguished road
hello
I think that if we would reduce the under relaxation factors then the result will take a lot of time to converge and if we dont change the under relaxation factors then the result will take short time to converge and it doesn't have any affect on the final solution.
So reducing under relaxation factors just only reduces the time if we disregard time thing what other benefit we can get from under relaxation factors. Please comment. Thanks
Mohsin
Mohsin is offline   Reply With Quote
Old   April 30, 2010, 10:02
Leonardo Giampani Morita
leonardo.morita is on a distinguished road
reducing under-relaxation factors can help a lot to achieve convergence in some cases, damping oscillations which may lead to divergence. Indeed, their use is almost always compulsory and you won't get your case converged if you don't set appropriate values.
leonardo.morita is offline   Reply With Quote
Old   April 30, 2010, 10:46
Mohsin Mukhtar
Can u tell me how to get the optimum relaxation factors or using the default would be good option rather than reducing or increasing.
I have a cylinder and air is coming from upside and goes into the 3 outlets.
My residual for conitniuty is 10^-5 it touches 2*10^-5 and then goes up and doesn't go until; 10^-5. I dont know what might be the problem.
Old   April 30, 2010, 10:59
Well, optimum values depend on the case but Fluent User's Guide recommends us to start with default values and eventually decrease them if residuals keep increasing.
And 10-5 isn't a bad value for continuity at all...once again it depends on the case, numerical schemes, initialization values etc. Search "continuity residuals convergence" in the forum for dicussions about judging convergence using residuals. You'll see that they're not that important...
Old   April 30, 2010, 11:03
Mohsin Mukhtar
ya you are rite but sometimes increasing relaxation factors decreases residuals.
Old   April 30, 2010, 11:57
Chris
Chris D is on a distinguished road
Residuals are a measure of how much the solution is changing in "time". Under relaxation factors limit how much the solution is allowed to change in "time". If you decrease the under relaxation factors, you decrease the rate of change of the solution, which you see as a decrease in the residuals. It doesn't mean that your solution is converged.
Chris D is offline   Reply With Quote
Relaxation Factors for Transient solvers philippose OpenFOAM Running, Solving & CFD 19 March 20, 2014 04:39
relaxation factors and time accuracy Mike Main CFD Forum 7 May 21, 2005 12:41
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
relaxation factors zhujianguo Phoenics 1 August 5, 2003 06:17
relaxation factors adjust zhujianguo Phoenics 1 July 15, 2003 11:11
