Solving Linear System of Equations in UDF
Old   April 25, 2010, 01:28
Default Solving Linear System of Equations in UDF
MOHSEN Zendehbad
mohsen zendehbad is on a distinguished road
Somewhere in my UDF i should solve linear system of equations(Ax = b), where i have A matrix and b vector and i need to compute x vector,
Now do any one know if there is an internal linear solver in fluent udf that i can use to compute x vector?
REGARDS
mohsen zendehbad is offline   Reply With Quote
Old   April 25, 2010, 09:05
DoHander is on a distinguished road
I think I've seen in one of the *.h files of Fluent a declaration for a Gauss solver (I don't have a Fluent installed on this machine to give you an exact name).
However I'm sure you can find on Internet a simple Gauss solver in pure C, you can simply use this function in your UDF.
Do
DoHander is offline   Reply With Quote
Old   April 26, 2010, 14:56
Precisely the above mentioned code is in linalg.h in your Fluent directory, this is a piece of code from the file:
void Gauss_Elimination(const int n_rows, const int n_cols, real A[], real X[], real B[], int swap_rows)
This is what you need ! (I hope)
Do
Old   April 26, 2010, 18:42
Arjun
arjun will become famous soon enougharjun will become famous soon enough
REGARDS
why you want to use fluent. Do you need this as a part of simulation.
if you do not need it as part of simultion than there are many libraries that would do it for you.
arjun is offline   Reply With Quote
Old   May 8, 2010, 07:48
MOHSEN Zendehbad
Isn't there any iterative method (such as GMRES or conjugate gradient) since gauss elimination is not responding to huge matrices?
REGARDS
MZ
Old   May 8, 2010, 10:39
I've found only Gauss, but you can search in all Fluent's *.h files from the udf's directory, maybe I've missed something (probably there are less then 100 *.h files so you can do a quick check).
If you want a more complex solver I'm sure you can link your udf with an open source math library (I said open source because you will need to compile this just like you compile your own UDF). Unfortunately you need a pure C library, I think GSL ( http://www.gnu.org/software/gsl/ ) may be a good choice, not sure how easy it will be for you to recompile it.
Or you can write a C wrapper for Lapack which is a state of the art linear algebra library, probably this will be more feasible for any operating system (Lapack is written in Fortran).
Do you use Linux or Windows ?
Do
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
advice needed in solving linear system yf yap Main CFD Forum 5 February 5, 2001 00:21
