ignition problem
Old   May 10, 2010, 22:09
Unhappy ignition problem
Ján
argeus is on a distinguished road
Hi to all,
Im trying to solve the hydrogen-oxygen flame acceleration transient 2D task using one part closed tube with obstacles. As the open part of the tube I use pressure outlet set up. As a ignition I use a ignition wall ( 4 little walls near the closed part of the geometry) with 2000 K, heat transfer coeff set to 10 - for the convection. Firstly, I run the task as a steady-state, and it seem to be no combustion at all. No pressure change, no temperature change, no flux. By the iterating, the temperature increased to about 2300 K (in a distant point) and then drop to default set up. Am I right, when I thing that steady-state analysis solve the problem in t -> infinity? But also no change occured with unsteady analysis. Where did I go wrong?..
Thank you in advance gentlemen.
argeus is offline   Reply With Quote
Old   May 12, 2010, 11:36
Ján
No one has a experience with hot surface ignition?
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
