How to specify an inlet boundary conditions for a fully developed gas flow in a duct. |
May 11, 2010, 04:08 |
Yang Xiaoguang
Dear everyone,
My model contains a rectangular duct with various kinds of gases flow through it. What I care is only the fully-developed region while I only know the mass flow rate. I found that if I specify the inlet boundary as a mass-flow-inlet type, the inlet region is not fully developed. So what kind of boundary type should I use in order to avoid the inlet developing length? Thank you. |
May 11, 2010, 05:30 |
Leonardo Giampani Morita
If you want a fully developed flow at inlet, you should firstly run another simulation, in which you impose periodic conditions or you have a sufficiently long developing region. Once you obtain a developed flow at the outlet of this system, you can write a profile (Write > Profile) for your velocity and then read it in your final case (Read > Profile). When setting boundary conditions, you'll see that this profile will be available ("constant" tab). See FLUENT User's Guide chapter 4.6 for some more details. |
May 11, 2010, 07:32 |
Yang Xiaoguang
I'll have a try and thanks for your help.
Boundary conditions for 2phase countercurrent flow | rakib | FLUENT | 5 | September 2, 2011 08:14 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
Fully Developed Boundary Condition at Duct Inlet | Twiti | CFX | 1 | January 24, 2005 01:31 |
Boundary Conditions | Jan Ramboer | Main CFD Forum | 11 | August 16, 1999 08:59 |
