May 11, 2010, 02:56 |
Re FLuent Journal
Harry
Rep Power: 17 |
Hi All,
I would appreciate your suggestion regarding how to run fluent journal step by step, just like that in gambit. Best Regards, Harry |
May 11, 2010, 04:56 |
John
I also want to know how to do that.
May 12, 2010, 02:03 |
Maxime Perelli
Rep Power: 41 |
from the help:
-------- ; Read case file rc example.cas ; Initialize the solution /solve/initialize/initialize-flow ; Calculate 50 iterations it 50 ; Write data file wd example50.dat ; Calculate another 50 iterations it 50 ; Write another data file wd example100.dat ; Exit FLUENT exit yes This example file reads a case file example.cas, initializes the solution, and performs 100 iterations in two groups of 50, saving a new data file after each 50 iterations. The final line of the file terminates the session. Note that the example input file makes use of the standard aliases for reading and writing case and data files and for iterating. ( it is the alias for /solve/iterate, rc is the alias for /file/read-case, wd is the alias for /file/write-data, etc.) These predefined aliases allow you to execute commonly-used commands without entering the text menu in which they are found. In general, FLUENT assumes that input beginning with a / starts in the top-level text menu, so if you use any text commands for which aliases do not exist, you must be sure to type in the complete name of the command (e.g., /solve/initialize/initialize-flow). Note also that you can include comments in the file. As in the example above, comment lines must begin with a ; (semicolon). |
Display Modes | |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
Problems With Journal When Writing Forces To File | Andrew | FLUENT | 2 | September 23, 2005 03:12 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 24, 2001 00:16 |
