Home > Forums > FLUENT
How to monitor the 3d blade cd, cl and cm
Old   May 18, 2010, 07:24
Default How to monitor the 3d blade cd, cl and cm
tom
caohan is on a distinguished road
Hi,all
Does somebody can tell me how to monitor the 3d wind turbine blade cd, cl and cm in fluent. in my model, the wind comes in horizontal direction and the blades have pitch angle. I want to monitor the life, drag and moment coefficient in every blade, does fluent can do that?
caohan is offline   Reply With Quote
Old   May 19, 2010, 01:01
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If you need to monitor them for each blade, then you have to define each blade as separated wall-BC. For instance blade1 , blade2, blade3.
Monitoring coefiicients is done in solve/monitors/force
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 19, 2010, 06:01
tom
Thank you for your reply, if the rotor rotate, does fluent can help me calculated the coefficient, because as I know, inside the monitor, I need to set up the coefficient with x,y and z direction which those vector are fixed.
Old   May 19, 2010, 07:03
-mAx-'s Avatar
Maxime Perelli
check help, especially chapter 25.18.3: Monitoring Forces and Moments
Old   May 19, 2010, 11:11
tom
very thanks for your help
Thread Tools
Trackbacks are On
