Home > Forums > FLUENT
Interface boundary condition
Like Tree6Likes
Old   July 9, 2013, 05:43
Sasan Ghomi
sasanghomi is on a distinguished road
Hi dear max ,
I dont know anything about size function Can you explain more? Or Do you have any tutorial??
Thanks and best regards
sasanghomi is offline   Reply With Quote
Old   July 9, 2013, 07:19
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
http://aerojet.engr.ucdavis.edu/gamb...ide/mg0502.htm
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 11, 2013, 10:06
Default error in interface VOF, FLUENT 14.5
  #23
Dimitris Romanas
Volumeoffluid is on a distinguished road
Originally Posted by -mAx- View Post
no need to use interface, you can use size function for that
Hi max,
i just read your comments and they are really intresitng. So i have a problem too and i ll appreciate if you can help me.
So i ll try to describe my problem.
So when i use VOF model my programm cannot recognize the two different phases. When i change one phase (air) automatically changing the other (water)...I don't understand why this happen.
Specially....there was this message: Unassigned interface zone detected for interface xx (This is the line between air-water)
I should define this mesh interface, but i dont know how exactly i can do this...
I adjusted some options in Meshing and Designmodeler but the same warning again.
I can send you photos of my project.
I dont know if it was better to use two different meshes
Thank you in advance!
Volumeoffluid is offline   Reply With Quote
Old   November 11, 2013, 10:15
-mAx-'s Avatar
Maxime Perelli
Again, don't mix "interface" in the sense of Mesh (here in Fluent) with interface (multiphase)
Post pictures of what you want to compute
Old   November 11, 2013, 10:23
Dimitris Romanas
nice!so could you send me your email to send you my geometry or some pictures?
My email is jimromanas@hotmail.com
thank you a lot!
Old   November 11, 2013, 11:44
Default bubble-wall
  #26
Dimitris Romanas
This is my geometry of my problem.
I hope i am clear of my questions
Old   November 11, 2013, 11:50
-mAx-'s Avatar
Maxime Perelli
explain your physics, where are phase1, phase2. Where is your "interface", etc...
Volumeoffluid likes this.
Old   November 11, 2013, 12:05
Dimitris Romanas
so from the left the half-circle is my bubble(air) and the other Rectangle is my surface (water).The line between these is my 'interface'. So i want o use VOF model to describe how is my bubble's behavior.
I have the same mesh both bubble and the other surface.
Old   November 12, 2013, 01:51
-mAx-'s Avatar
Maxime Perelli
As I said, forget interfaces.
Reconnect both domains (connect edges (All)), but keep your split line (half-circle)
Then you have to define 2 continuum types:
one for air and one for water
https://www.sharcnet.ca/Software/Gam...zone_cont_type
Then later in fluent you will be able to set your vof properly
EDIT: Next post remind me that you are probably not working with Gambit...
Old   November 12, 2013, 03:02
vidyanand
Vidyanand Kesti is on a distinguished road
Interface is just connect the mesh or grids and help to flux transfer, If its automatically creating interface in the fluent please check in the ANSYS mesher, delete the connection in the AMP, if you check the grid check in fluent its shows the warning because of interface, define the interface in fluent to avoid the this warning, If you get the wall between two interface means in model it had gap in between the two interface ,so convert to interior or back to model fill the gap either by solid extrude or extrude
thermal energy likes this.
Vidyanand Kesti is offline   Reply With Quote
Old   November 12, 2013, 12:16
Dimitris Romanas
Thank you both for your answers.So,
dear Max i did exactly what you said, but when i go to fluent, it was created two BC for this split lines (half-circle)...one is from bubble side and the other from surface side. So for one line, there are two lines. I had name selection but the fluent create and the other line for surface side. I dont use anymore interface.What should define these lines?as wall??and mesh motion and in VOF model (explicit sheme---> Geo-reconstruct) ??
i have defined the (before used VOF) two cell zones(one with air and other with water)...but again when i used VOF, when i change one cell zone condition automatically the other same change.
P.S i use Ansys Fluent 14.5.7 (DesignModeler- Ansys Meshing- Ansys Fluent)
Dear vidyanand.kesti@mann-humm,
in Ansys Meshing i disabled automatic insert contact region. So i have only in my outline tree one Connection. Nothing Else. And i did exactly what i had described above.
I am looking forward your answers
Thank you!
Old   November 13, 2013, 01:33
-mAx-'s Avatar
Maxime Perelli
If you don't have Gambit, then you cannot do what I mentionned.
I let other people helping you since I don't know Ansys Meshing
Old   November 13, 2013, 08:08
Dimitris Romanas
Ok Max thank you a lot for your mentions, but
do you know someone that he can help me??
i should contact immediately with him!
Old   November 13, 2013, 08:27
-mAx-'s Avatar
Maxime Perelli
Maybe Far can help you
Old   November 13, 2013, 08:33
Dimitris Romanas
Because i dont know him (Far), can you send me his profile or URL something to find him?
Thank you!
Old   March 20, 2014, 05:32
thermal energy is on a distinguished road
dear vidyanand,
when ı check the grid as you said it shows warning because of interface, how do ı define interface in fluent. ı have phase change materias-air interface. they dont penetrate eachother. ı define this line as an interface boundry condition but ı have error.thanks for your help.
WARNING: Unassigned interface zone detected for interface 5
Error: Init_Flow: unassigned interface_zones
thermal energy is offline   Reply With Quote
Old   October 22, 2014, 03:48
Smile liquid saturated porous-vapor interface
  #37
Bill Wang
6863523 is on a distinguished road
Originally Posted by thermal energy View Post
dear vidyanand,
I am simulating the evaporation right now. I have no idea whick kind of boundary type should I specify for the porous-vapor interface.
The porous is saturated with liquid water. There is a heat flux at the bottom of the porous. The evaporation occurs at the upper surface of the porous.
http://www.cfd-online.com/Forums/mem...interface.html
In fluent, what kind of boundary type should I choose for the interface to let the liquid water flow into vapor region.
I used Gambit to mesh.
Since the porous rigion and vapor region overlaps, I named the overlapping two edges as interfaces.
http://www.cfd-online.com/Forums/mem...-interface.png
After I imported the mesh, I created the mesh interface correspondingly as below.
Thank you in advance. I have been stuck here for a long time. My email: 815719752@qq.com
Hope to hear from you soon.
Best Regards,
Bill
6863523 is offline   Reply With Quote
Old   January 19, 2016, 04:29
sujeet
ksujeet213@ is on a distinguished road
hii guys i am new in cfd....i have an question?
how to apply boundary condition at interface?
ksujeet213@ is offline   Reply With Quote
Old   January 19, 2016, 04:36
pakk will become famous soon enough
You should tell us what you really want to do. Which problem do you think you can solve by putting a boundary condition on an interface?
pakk is offline   Reply With Quote
Old   January 19, 2016, 05:31
sujeet
my question is
for piping networking analsys where at interface portion i want to provide pressure drop for heat exchanger on mixing network route?
Thread Tools
Trackbacks are On
Problem with Interface Boundary Condition tos FLUENT 0 April 4, 2010 08:11
Boundary condition at the interface of two fluids bhaskar FLOW-3D 1 May 22, 2009 16:34
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
SymmetryPlane Boundary Condition raytracer OpenFOAM Running, Solving & CFD 0 July 11, 2008 17:04
interface boundary condition definitions? Skander FLUENT 1 November 2, 2006 16:47
