how do i create fire in fluent to simulate smoke |
December 31, 2008, 05:19 |
Hi all,
Does someone can help in this matter? This is my assigment and I'm new to CFD. How do I create fire in Fluent to simulate the smoke dispersion. Pls help me..... |
January 1, 2009, 06:22 |
Re: how do i create fire in fluent to simulate smo
You can either use the combustion models available to simulate the fire, or you can model the fire as a fluid zone with a heat generation source.
Hope that helps. |
June 3, 2009, 10:00 |
Car ParK Simulation
Abdelkader Benzamia
Rep Power: 16 |
Hello Evry Body
I am doing for a car park smulation. To simulate the smoke? I put a passif scalar as smoke with velocity and temperature are equal : 1m:s ans 700 K. I want a real case, I want to see the mass fraction of Co ans Nox, Visibility I want to the full job in this kind of problems. Please help me |
June 4, 2009, 02:03 |
smoke spreding
Svetlin Filipov
Rep Power: 17 |
For gas distribution use multiphase model and define all species that you want. I think it is not necessary to model the real flame... this will not give you more information but will give you modeling problems.
June 4, 2009, 02:38 |
Abdelkader Benzamia
Rep Power: 16 |
Thank you for your reply,
To simulate a real case can you help me to put the right data. Mass fraction of co, and nox ..., Masse flow, or velocity, and temperature. Thank you again. |
June 4, 2009, 03:06 |
Svetlin Filipov
Rep Power: 17 |
Species fractions depends on what is burning, conditions of combustion, air speed and many others ... if you model an exact combustion process your task will be very very specific.... if you what to model smoke distribution then take typical gas fractions in combustion of the fuel you want, take typical BC (heat source, velocities, Pressure...)and use unsteady solver...
June 4, 2009, 03:21 |
Abdelkader Benzamia
Rep Power: 16 |
Thank you againe.
This is my provleme, advice me please, Advice me for a real case and boundary conditions. thank you so match |
June 4, 2009, 03:34 |
Svetlin Filipov
Rep Power: 17 |
Give me scheme of the situation, type of fuel, place of burning....
June 4, 2009, 03:41 |
#9 |
Abdelkader Benzamia
Rep Power: 16 |
A real case for car park scenario.
Thank's |
June 4, 2009, 03:46 |
#10 |
Svetlin Filipov
Rep Power: 17 |
if you want someone to help you must be more informative... what is the type of fuel that is the source of the fire...
#11 |
Abdelkader Benzamia
Rep Power: 16 |
Let's take a combustion of methane for example.
June 4, 2009, 03:56 |
#12 |
Svetlin Filipov
Rep Power: 17 |
It is not possible to say (let's say methane)!!!!!!!!!! products from methane combustion are CO2 and H2O ... so in that case you what to model CO2 distribution so... you just model air and CO2 with let's say 0.02 kg/s... with the information you give I can not do more..
June 4, 2009, 04:03 |
#13 |
Abdelkader Benzamia
Rep Power: 16 |
I will comback to you form details,
I wil try to be clear, the problem is this kind of situation is new for me. I have looked for other publications and the show only results without details of boundary conditions. Thank you very match againe. |
October 9, 2009, 14:28 |
#14 |
Abdelkader Benzamia
Rep Power: 16 |
I comback to you withe more details about my simulation.
Fire scenario inside a tunnel : burning 500 l of diesel in 6 min average released power of 44.4 MW The fire is modelled using a volumetric How could i set up those boundary conditions in fluent Best Thank you for all. |
May 28, 2010, 02:31 |
#15 |
S.M.Sumon
Rep Power: 16 |
I wanna model a fire placed at the bottom of a sealed room. how can i do do and do u know about any tutorial or related paper of it
please help me. i am new in this things |
Fire & Smoke in Building | Jenn | FLUENT | 5 | December 29, 2012 23:15 |
smoke (fire simulation) | matt | Fidelity CFD | 0 | January 5, 2007 04:47 |
smoke (fire simulation) | matt | Main CFD Forum | 0 | January 5, 2007 04:45 |
Could FLUENT simulate the smoke? | Saturn | FLUENT | 0 | July 13, 2004 00:30 |
Fire/Smoke Modelling | Roger | Siemens | 1 | November 27, 2002 02:37 |
