July 22, 2008, 20:40 |
plot surface elevation
Hello everyone
I use the VOF model in Fluent to propagate waves along a slope. I use variable time step method, unsteady solver. I use 2ddp version and UDF files for the inlet conditions. How can i plot the surface elevation as a function of time at a specific point that I am interested in? I do not see any options at display or plot panel.. Thank you in advance |
July 22, 2008, 20:59 |
Re: plot surface elevation
Setup a line at postion you want to monitor the level at. Then Iso-clip the line to volume fraction of 0.5. Finally, setup a monitor of maximum y-coordinate on the clipped line.
July 23, 2008, 09:54 |
So to understand this properly because i am not a Fluent expert, i need to plot the surface elevation at a specific point which is located underneath the initial water level. Do i need to create a vertical or a horizontal line?
And then at iso-clip there are 2 values to enter for volume fraction. Min and max. Which of them should be 0.5 and what is the apropriate value for the other? And finally, when plotting y-coordinate, do i need to set area-weighted average for the y-axis?or something else? Thank you again |
July 23, 2008, 17:21 |
I'm assuming that your surface elevation is horizontal so you need to create a vertical line. This makes it perpendicular to the surface.
Iso-clip the line with min=0.5 and max=1 volume fraction of the fluid that you want to monitor. Just display the line after you clipped it to make sure its right. It should go from y=0 to y=surface elevation. Set the monitor to Vertex-maximum for Y-coordinate. This will return the maxium y coordinate of the clipped line. |
July 25, 2008, 07:29 |
It really worked exactly as i wanted to... Thank you very much
June 1, 2010, 11:53 |
Rep Power: 16 |
Hi
Someone could explain me how to plot a surface elevation graph in a determined flow time where: x - x distance; y - surface elevation elevation. |
Display Modes | |
Time Chart of Surface Elevation | MAB | CFX | 10 | February 27, 2016 18:45 |
STL units and Surface elevation plot | MAB | FLOW-3D | 11 | May 9, 2010 15:55 |
Variation In Water Surface Elevation | Umm... | FLUENT | 0 | December 10, 2007 00:14 |
Free surface plot | Juan Martin Catelén | CFX | 6 | June 1, 2007 15:03 |
ploting surface elevation | Tony Campbell | Siemens | 5 | January 29, 2005 16:09 |
