BC for free surface in open channel
Old   March 18, 2010, 01:00
Default BC for free surface in open channel
Nikhil
nikhiljain.iitk is on a distinguished road
wat would be the BC for Free surface in setting up 2D straight open channel ?
nikhiljain.iitk is offline   Reply With Quote
Old   March 19, 2010, 12:01
esgee is on a distinguished road
The viscosity of a gas is usually much smaller than the viscosity of a liquid therefore you can estimate that the shear stress is zero in the boundary.
esgee is offline   Reply With Quote
Old   June 1, 2010, 15:54
Ross Mullen
Kangaross is on a distinguished road
I am very new to Fluent and self taught so try to keep answers simple as possible.
Going along with the post two above. I have a rectangular cross section with open channel conditions.
For the BC of the inflow ( I have water and air as my fluids) do I need to do something special?
I set up Multiphase flow. Checked Gravity and Open Channel Boxes. Set up materials and the solver. After iterations and taking the display vector approach, I discovered from the velocity profile that only water was being used.
However upon further examination I believe it is combining the two fluids, instead of having the air on top and the water on the bottom. How do I separate them? (I believe this is done by specifying BC's which is why I put this reply here)
Additionally I do not know the water level, because it is dependent on flow so I am confused what to do.
Thanks in advance.
Kangaross is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
pressure outlet (open channel flow) Willem Brantegem FLUENT 2 April 4, 2007 02:40
VOF scheme for open channel flow yan FLUENT 1 May 21, 2005 00:21
open channel flow Frank Main CFD Forum 3 December 15, 2000 03:32
