I have a problem with the sign of mass flow rate Enthalpy |
June 6, 2010, 18:02 |
Behrang Asgharian
I put some Lines (from the menu 'surface-line') on my model in order to monitor the enthalpy flow rate. I use the flow rate integral which is
integral of rho*h*u.dA the absolute values are OK but the sign is negative when it must be positive. I think this has got something to do with the inner product of u.dA. Does anybody know how I should define the monitor line in order to get positive enthalpy flow rates? By the way, if I use 'surface-rake' instead of 'surface-line', what will happen? Thanks Behrang |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 21:02 |
mass flow rate of "interior" | Dong Fu | FLUENT | 0 | February 1, 2008 11:25 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
Mass flow rate | Neser | CFX | 4 | February 14, 2004 00:27 |
Possible?: Periodic conditions with non-constant mass flow rate. | Ray | FLUENT | 0 | April 10, 2000 06:10 |
