How to Use Experimental Data in Fluent?
Old   June 8, 2010, 04:56
Default How to Use Experimental Data in Fluent?
Floyd
Floyd is on a distinguished road
Hi
I am a student and currently doing a research on a thermal management system of a cylindrical lithium ion battery. The discharge temperautre of the battery was measured experimentally and that was actually a temperature V.S time curve. I would like to know how I could put the whole set of temperature V.S time data into fluent to carry out my simulation?
Thanks!
Floyd
Floyd is offline   Reply With Quote
Old   June 11, 2010, 04:45
Floyd
I would like to know if it possible to use a time dependent heat source term in the simulation since I only see the constant source term setting. thank you!
Old   March 7, 2018, 13:55
Default Li-ion battery
SD
uselokar is on a distinguished road
I would like to know , how to plot the C-rate graphs and voltage distribution using MSMD battery module in ANSYS fluent
uselokar is offline   Reply With Quote
Old   March 7, 2018, 23:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
C-rate graphs and voltage distribution are using to estimate parameters for electro-chemical models
Best regards
AlexanderZ is offline   Reply With Quote
Old   March 8, 2018, 11:09
Default uselokar
SD
Thanks for the reply
How we can plot the current distribution graphs which should show variation in cell bodies.
Old   March 8, 2018, 21:23
Alexander
Graphics -> contours -> User defined memory (under contours of) -> Magnitude of current density
Best regards
Old   March 9, 2018, 12:07
SD
Thanks! It works
Old   March 9, 2018, 12:10
SD
i am simulating Li-ion battery after I pop-up the Run solution message reflects" zone 16 is not connected to conductive zone ". How to resolve this .Is their any option to resolve this error without changing the geometry.
Old   March 11, 2018, 21:36
Alexander
as far as I know, usually the only way is to change geometry
without geometry I can't advice
best regards
Old   March 12, 2018, 16:16
SD
I have attached a picture and i stuck with an error while simulating in ansys fluent. the file is attached below. How to solve the overlapping with interface zones
Old   March 12, 2018, 20:31
Alexander
obviously you have problems with mesh.
Generate new one, first of all delete all contacts
best regards
Old   March 12, 2018, 23:01
SD
Thanks I will try and let you know.
While simulation error shows : " Divergence detected AMG solver :temperature".
How to get rid off from this error.
Old   March 12, 2018, 23:35
Alexander
I believe, that for your case this error comes from problem with mesh.
best regards
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
how to provide accurate inlet boundary condition from experimental data? swe704 FLUENT 0 September 29, 2009 04:01
UDF and experimental data in Fluent Rogerio Fernandes Brito FLUENT 0 November 25, 2008 09:32
Plotting Contours of Experimental Data Umm.. FLUENT 4 February 20, 2008 16:27
Can somebody help me get some experimental data? xiaozhu Main CFD Forum 1 January 16, 2002 09:41
